Now i'm under my jeep
I'm retorque my new lift kits and shocks now..
But something cnfusing
That upper one is front track bar that came from rock krawler right?
I tried to retorque it with 125 ft torque.. But it keep go for it.. The nut is turn together when i retorque bolt... So do i have to hold it by using some spanner?
And also front upper shocks can't do it no space.. I need car jacker? Something can lift my car little bit to make space
you need to use a 21 mm wrench to hold the nut on the back so you can torque the track bolt bar down. For the upper shock bolt, I use a closed end wrench with a slight kink in it so you can access the nut
Yep, u need to hold the other nut with a wrench, which can sometimes be a challenge cause you have to hold it tight while torquing. What I did was I put the wrench on the other side and supported the wrench with a ca jack for support.
and also if you use closed wrench for upper front shocks.. how do u adjust torque? closed wrench is not torque wrench right?
Originally Posted by D_engel
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=358359"/>
it looks something like this.
As for doing the torque on the upper shock bolt, i always just feel it out. I see no need to use a torque wrench on something like that. It sees no lateral movement and there are bushings which compress when you tighten it down
