Not another gear question!
In the first 100 miles, no driving over 60mph and don't go more than about 30 miles without stopping long enough for the axles to cool (temperature cycle). Don't drive at a constant speed for too long. Go easy on acceleration/deceleration.
No towing or off-roading for the first 500 miles.
Keep an eye out for leaks and an ear out for strange noises. There should be neither. Drain, inspect and refill with the good stuff after 500 miles.
I don't dispute the importance of the installer looking at the wear after a period of time, to verify the install, but I question that break in method or at least the need for it.
Just curious
Forum Tech Advisor
So, I have hear this numerous times over the years. But.... When you buy a new car/truck/whatever off the lot it has no miles on it. You buy it, drive it off the lot and head down the freeway at 75mph and drive it home. No break in, no requirement to break in, etc. They function just fine. Why would you need to do this when you regear? I don't dispute the importance of the installer looking at the wear after a period of time, to verify the install, but I question that break in method or at least the need for it. Just curious
Special break in oil is used.
Still, your owners manual gives break in requirements for new vehicles--including max speed, restrictions on towing, etc. for early miles.
Factory gears are lapped and engines are run on the assembly line.
Yep, engines are started, cars driven off the assembly line and run in a booth for 30 seconds or so. Run up to 60+mph, then brake hard. If it passes then output to the dealers. I worked for GM ( Caddy plant) a number of years ago.
Which most people will not change, even in the recommended intervals. Why would would the same not be required in a regear situation?
Not saying don't do this. Just playing devils advocate for some good discussion
Forum Tech Advisor
Again, which almost no one ever follows. Have you ever seen anyone read the owners manual before they drive the car off the lot? I have never had a dealer tell me to do any kind of break in either. Have purchased in excess of 25 brand new vehicles in my life.
I even go beyond this with jeeps or Ram trucks. I go under the assumption that the dealer may have been sloppy on their PDI, or at the manufacturer and re-torque the suspension components.
Almost no one ever follows? People are stupid enough to buy a brand new vehicle and not follow break-in procedures?
Anyway, the factory gears are lapped so that the splintering/debris affect of the break-in is less. You get new aftermarket gears installed that haven't been lapped, and you will find the magnetic plug will have a good amount of material on it at your 500 mile differential fluid change after break-in.
This is easy to test yourself. If you have never changed your diff fluid, change it now and see how much debris there is on the magnetic drain plugs. Then, regear--following recommended break-in procedures--and change the diff oil at 500 miles and see how much debris there is on the magnetic drain plugs as a comparison.
