North Ridge grade 8 hardware kit question??
Old 04-19-2012 | 06:30 AM
Prime8's Avatar
Originally Posted by ASSFROW
Hello,
Is there any reason not to use stainless hardware? I luckily have reletives that run a harware distributor and can get stainless cheap.
Thanks,
Gary
As long as its a grade 8 equivalent you should be good. Most people stick to zinc coated steel because stainless is more expensive and doesn't provide a whole lot more benefit. But if you have a connection, go for it.
Old 04-19-2012 | 07:09 AM
ASSFROW's Avatar
Thank you sir!!
I couldn't think of a drawback, but it's still early and I need coffee!
Thanks again,
Gary
Old 04-20-2012 | 10:15 AM
eumel789's Avatar
Hello,
Thanks,
Gary
No way! SS bolts are not rated even close to grade 5, and you need grade 8!
Old 04-20-2012 | 10:41 AM
OH9JK's Avatar
JK-Forum Ambassador
Do not use stainless hardware!!
[attach=config]306960[/attach][attach=config]306961[/attach]
Name:	Bolt Depot - Bolt Grade Markings and Strength Chart_Page_1.jpg
ID:	306960   Click image for larger version
Name:	Bolt Depot - Bolt Grade Markings and Strength Chart_Page_2.jpg
Old 04-20-2012 | 12:13 PM
Inko's Avatar
My RC Track bar came with the proper sized bolts.
Old 04-20-2012 | 12:34 PM
Croce's Avatar
I have the RC trackbar and the end that attaches to the frame wouldnt accept a 9/16 bolt
Old 04-22-2012 | 03:38 AM
ASSFROW's Avatar
Thanks for the heads up!!!!
No Stainless.
Gary
Old 05-07-2012 | 08:39 AM
Marksteven77's Avatar
Does anyone know what (if any) torque settings the bolts should be at? I have the bolt upgrade kit from Northridge and was told to make it "more than hand tight"...is this correct?
Old 05-07-2012 | 08:42 AM
DanieltheManual's Avatar
125 ft lbs....
Old 05-07-2012 | 08:49 AM
125 ft-lbs...roger. Thanks buddy!
