Normal axle movement?
#31
Did you happen to raise the rear trackbar also? Or just the front?
I have seen several posts indicating that it is ok to raise the rear without raising the front --> but raising the front without raising the rear can cause issues. (though I haven't read exactly what that issue is. Maybe the directional pull on accelerating/braking you are getting?)
#32
The rear was raised many years ago. I'm going to try this in reverse, this may tell me if I have something loose. If it does in reverse then I do. If it doesn't then its suspension geometry?
#33
May or may not be relevant but make sure when you try to diagnose any movement or issues remove your stabilizer, it's job is to buffet any issues you have. I spent a month trying to figure out an issue I had, till I removed the steering stabilizer, and the issues became obvious.
#34
Also ... If the drag link is not flipped or (cough) a drop pitman arm. You will have bumpsteer.
Most kits raise the rear about 3" for a 2.5-3" lift which will help. I woundnt worry about the front.
#35
I believe my caster is at 4 degrees. I would have to double check though. I bought myself a big ass torque wrench tonight so now I can torque things down properly and much easier. I believe my mounting locations are fine, no play in the bushing from my video I took tonight however I will need a closer inspection with a driver moving the wheel to really see.
Read pinion angle off the front flange. This will give you a pretty accurate caster angle. Make sure you are on perfectly flat ground.
Stock pinion angle is just shy of +2* and caster around 4.2* = 6* between the two.
#36
I found a loose bolt, after tightening it up I still had problems. I disconnected my sway bar to see if body roll had a play, no difference. Checked all the nuts and bolts for torque, all tight as hell. So I can only surmise its my suspension geometry. I have a drag link flip kit coming my way, once I get it on I will see and report back.
EDIT: I did put my enclosed trailer on Monday and found it would not veer left nearly as much when towing. During my testing while not towing if I have it a 2nd gear and can make alot of torque it will veer alot, I can actually steer with my throttle. However my wheel is not moving, so that leads me to believe something is loose. It drives awesome on the highway.
#38
#40
Ive driven my Jeep around the block like that while I was waiting for my steering knuckle insert to show up and it had the exact same symptoms. I just wanted to see how it felt and it is damn sketchy. I don't know how he drove like that for so long.
