Noisy soft top questions
My girlfriend and I just had our first child and I'm looking for ways to make the interior a little more quiet for my daughter. I have a Bestop Sailcloth soft top, that helps a little. Does anyone have any experience with Bestop's headliner? Also, my header is just a tiny bit loose on the passenger side, so I know that would account for some noise, any suggestions for that without replacing the header? I have a feeling they all eventually do that. I was thinking wind deflector?
ATXFIREMAN - did you ever try one of the wind deflectors? I was thinking about going this same route, but didn't know if it would help with the noice any. Almost seems like it would have to.
I just bought my '08 so its out of warrenty, but I need to call and see what it would take to get my header panel replaced with the metal one. If the top is opened, is it easy enough to tell what header panel i currently have(plastic or metal)?
EzK - I'm a newbie as well but here is some info that I found on here while searching...there seems to be possibly 2 fixes for the wind noise - one of them deals specifically with the sunrider softtop:
TSB 23-010-09 Rev A - Part # 68049276-AB The complaint/cause was wind noise.
TSB 23-002-08 - It is Part#68026937AB, "Replacement Foam Kit (Jeep JK)", as referenced in TSB# 23-002-08 "Soft Top - Water Leak At Upper A-Pillar Door Seal To Door Rail Interface
SUBJECT:
Wind-Like Sound At Outer Ends Of The Sunrider Soft Top Windshield Header
OVERVIEW:
This bulletin involves replacement of the left and right soft top front side bows.
As far as the warranty, I think it's just making a trip to your local dealer and showing them the TSB's and going from there.
Hope this helps!
SUBJECT:
OVERVIEW:
Hope this helps!
Exactly what I did. The dealership covered all cost because there was a TSB on it. It replaced the crapy plastic one with a metal one. Noise almost completly gone, before it sounded like I was in a wind tunnel. Now its almost as quiet as the hard top.
I have an 07 and it is noisy as all get out too. Should I call the dealer and talk to them about it and if they'll replace it or just take the jeep in?? Oh, and what do you guys mean by TSB? Also, anyone know the part number for the metal header? Thanks
