noise when in 4wd
noise when in 4wd
So I've got a nasty sounding noise when I go about 10mph in 4wd. Its like a grinding clicking noise. I have about 2mm of play in my front driveshaft joint with the boot on it. Any thoughts?
Not that this may be it, but I was told, "You broke a pin in your front pumpkin that is causing your spider gears to bind."
I was getting a noise similar to what you described. I would only hear it in 4WD, and it was even worse when I turned hard left or right.
I too have about 1-2mm of play in my front DS u joint, but was told that wasn't my problem and that is normal.
So now I'm just looking at regearing and adding lockers since I've got to get it all fixed now.
If it was axle related, it would make the noise in 2wd as well. Before you blame your t case, remove your front drive shaft and then go test it in 4wd. If it still does it, then you can definitely eliminate anything t-case forward.
The JK t-cases are really solid and unless you didn't take care of the fluid, it's unlikely to be internal.
Keep in mind that the front drive shaft (and therefore t case yoke) also spin in 2wd since the front axle doesn't have free hubs.
