No power with the top/doors off
When cruising on the highway ill be sittin in 5th gear and the slightest incline i will lose momentum even tho I'm flooring it sometimes i hav to shift all the way down to 3rd to pick up and maintain speed i figured since its terribly un-aerodynamic with the doors and top off thats the problem and im sure running 35s with stock gearing is also contributing.... i just wanna see if this is normal and if any has any suggestions to help out?
Normal. Mines an auto and it was very common until I installed 5.13's and then it was less frequent (only larger hills and long more gradual inclines ). Then I supercharged it and no longer have that problem. (Expensive "fix").
You need to do both front and rear gears or you will have a catastrophic failure!
Ok thanx man once again is it ok just to regear in the rear or do u have to do the front and rear at the same time and also is there anything else besides the ring and the pinion? Do i need a whole new dif or driveshaft or anything ...can u resize the gears in the stock difs?
You will need a ring and pinion and depending on the millage of your jeep, you will need either a master overhaul kit or an install kit.
You don't need a whole new differential or driveshaft.
You can regear a Dana 30/44 combo up to 5.13 gears. And regear a Dana 44/44 combo up to 5.38 gears.
