No Lift 35"
No Lift 35"
I would like to put 35" tires on my 08 Rubi Unlimited without lifting the body. I and my wife have short legs and I would like to keep the center of gravity as low as possible for crawling. Any suggestions or write up I can read? thanks, Spiritree
Flat fenders, trim the rubi rails, a maximum of 4.5" back spacing and bend in the pinch seams. Some minor rubbing at full flex and there are a couple threads on it if you do a search.
35" on with no lift or rubbing
07 Rubicon with no lift yet. I had to try and put them on while I was waiting for my 2.5" Tereflex to come in. I did not believe that they fit and that there is no rubbing at all. I almost considered not running the lift at all but if you do any wheeling or even hit a big enough pothole you might rip the tread right off a $300 tire and do some serious damage.
