No lift 2012 rubicon squeezing 35's
Old 03-03-2012, 08:32 AM
Trailslayer's Avatar
Default No lift 2012 rubicon squeezing 35's
Just picked up a 2012 Rubicon yest and unfortunately moving across country so no time to put a lift in yet.... will I be able to squeeze my 35x17 on there with maybe just a fender/ front bumper chop. Any info is a help
Old 03-03-2012, 08:43 AM
p1llar's Avatar
I know for pre '12's you will rub, so i'm assuming it would be no different for yours.
Old 03-03-2012, 01:39 PM
cg07sut's Avatar
You will most likely rub, had a set of 34's on mine with a 2" zone bb and had some slight rubbing in forward and reverse when turning. I had more than adequate backspacing, you will also have to trim the rear pinch seam
Old 03-03-2012, 01:41 PM
jakes's Avatar
35's should be fine for on road. but offroad oh man
Old 03-03-2012, 01:48 PM
JKTXJL's Avatar
lol i have a 2012 w/ TF 2.5" and 35" trail graps and I get a lil bit of rub at full turn
Old 03-03-2012, 02:43 PM
kylepage's Avatar
you can sit in a parking lot! cant drive..tryed it and you will rub on your rubi rails the second you hit a pebble on the road. beeen there tryed that. just wait.
Old 03-03-2012, 06:51 PM
bo9roadking's Avatar
I put 35" tires on my 2012 JKU when I drove it to the shop for the lift install. I didn't want to figure out how to transport my 35" tires to the shop after the lift was installed. The tires rubbed several times during the 20 mile road trip. I wouldn't recommend it.
Old 03-03-2012, 09:03 PM
notsoricer's Avatar
i had my tires installed before i got my lift and the precautions i took were to put teraflex bumpstops on the rear axle and i had the tire shop neatly trim my front air dam a little. i had zero rubbing on average driving for about two days. rubi rails come close but you can sawzal an inch off the rear sides. by all means you don't want to do this for long term because its just simply not safe especially if you hit a hard bump at high speeds or run over your curb and knock a fender off. but if its short term to get from point a to point b for a few days, you'll be fine. the dealership that i bought my jkur from puts 35's on stock jk's but i don't know what the outcome is.
Old 03-04-2012, 12:55 AM
dinojeep's Avatar
You leaving the 'cuse?!
Is wait until your final destination and then put on the 35s.
Old 03-04-2012, 03:56 AM
1FoxyJK's Avatar
Get some flat fenders or trim yours and you'll be fine for the time being.
Quick Reply: No lift 2012 rubicon squeezing 35's
