No horn.
No horn.
Little info about the jeep. 07 jku with a mild lift and 35's no electrical upgardes. For the past year or so now I have not had a horn. Just the other week the horn went when attempting to lock the doors. I replaced my clockspring and still nothing. All fuses are good. Any one else have any guesses?
If you find no voltage at the horn connector...
Have someone press the horn button while you listen carefully at the fuse box (TIPM) for the faint clicking of the horn relay, which is buried inside the TIPM on a printed circuit board. It's very faint, so make sure there is as little ambient noise as possible.
I get clicking at the tipm when using the key fob but not the horn itself. I triple checked the fuses and all look good, I changed out the fuses at m 22 and m23 just for shits and giggles. When I changed the clockspring, my airbag light and blinkers no longer act up. Any chance it's as simple as a bad horn?
Have you checked for power at the horn connector when the horn button is pressed?
Have you connected the horn directly to the battery to see if it works?
