no gear change on automatic transmission
I have 2011 JKUR with 193,000 miles. The other day I was driving and my Jeep would not go into 4th gear. First chance I had I pulled over and turned my Jeep off. Waited a minute or so, then started back up. After that I had no problems. Just took her home and let her rest for the remainder of the day.
I mentioned the issue with a friend and he said that it could be my transmission cooler lines. I have no leaks and the transmission fluid is not low.
Has as anyone else seen or heard of this problem? If so what was the solution. Thanks.
