Nitto Tire Weight
Those are the tires I run exactly. They are very nice I think. Two tires took zero weight to balance and only a slight index and the others all took under an ounce. They are heavy relative to many other tires thou just like the toyo sister tires. So 70+ pounds sounds about right. They are heavy sidewall ply tires so ripping a sidewall shouldnt be an issue, they are E load rating so I run at 28 pounds of air in them fully loaded, with bumpers, skids, rack, rails, spare, tools, compressor, etc. They measure out at 34 inches measure off the ground under that load and psi. They also are relatively quiet.
So I have been all over the interwebs and used the Bing machine to search for specs on some Nitto Trail M/Ts I am looking at.
295/70/18s to be exact. Nitto site has them at a hair over 34.5 inches vs my current Duratracs 275/7018 and 33.2 inches. My Duratracs are 55lbs according to Tire Rack. Only thin I could find on the Nittos was an Amazon listing that had the shipping weight at 71.6 lbs a piece!!!!! Can this be right?
Its not even a full 12.50 width tire and almost 72lbs? I'm trying to go easy on my front Dana 30 and my wallet by not going with a full 35 x 12.50, but at 72 lbs I think I will have to get a PR 44.
Anyone think this seems especially heavy for a 34.5" tire? Any others you would look at?
18" wheel.....
18" wheel.....
Tire weight will damage your axle and so will width, not saying this amount of weight will but in general. Your housing most likely will never get damage. Ball joints, u joints, and axle shafts will go before anything else. If worried buy gussets and swap those parts out.
Thanks fellas....when you say true....do you also mean true to size or just very easy to balance and such?
By the way...I know KM2sand some other tires run notoriously small when mounted....how about the Nittos?
My Duratracs measure out 32.3 mounted....on a published size of 33.2 running 28-30 psi...I'd say that's pretty good.
If your feeling strain from a 35 man up. Try doing a 107lb 40 on a 40lb steel wheel.
You will not need a pr44 to run those tires. I run them in 35's on a D30 with no problems. Much of this depends on how you drive/abuse it off road. Definitely have some gussets welded on either way
