Nitto Ridge Grapplers
Sponsoring Vendor
Former Vendor
Mel Wade tried out a new set of Nitto 37x12.50R17 Ridge Grapplers at JKX Alaska and was impressed. This write-up should give you a good idea of the experience: http://www.drivingline.com/articles/...of-jkx-alaska/
I had those....be careful...because even after 2 years I never could keep them balanced....was so bad I thought I had death wobble for 6 months....switched out tires to gladiators....problem solved. Afterwards I read that a lot of others had same problem. Just my experience though.
Note this doesn't mean either company can't make a bad batch, any company can. And it doesn't mean other tires aren't great either. I'm only speaking on a large margin of reviews, experience, others in my area, that you have a really high chance of a good experience buying Nitto or Toyo compared to some other brands
Toyo MT's
The ridge grappler is a brand new tire so I assume you mean the Toyo MT. And in 6 years this might be the first time I've read a comment about the Toyo MT about balancing issues. I've ran them in 35s,37s, and 40s. Each time amazed at how well they balance and drive on the street. Even had shops tell me it's the "easiest big tire" they ever balance. Little as 1 to 2 ounces. Maybe you didn't take proper care of them? How would anyone know. Maybe you got a defective set and it took 2 years to show itself? Anyone's guess I suppose. As far as balancing over sized tires, there is enough info out there that both Toyo and Nitto make some of the best well rounded tires that balance easy
