Nitrous oxide
#31
People rant and rave about the late 4.0l. It was a great engine design, but poor quality control caused a lot of early failures in them. The 4.0l in my '96 XJ went at 60k miles. I suspect that the 3.8l is the same way. They too have developed a work horse reputation in the work fleet sales. Especially, its cousin the 3.3l.
#32
I am one of those people that has to "see it to believe it", I have heard as many good as bad things about this install on a "stock" 3.8 motor. Since I have built many motors in the last 20 years, many for NOS, blowers and turbos, I can say without any doubt, unless this blower is running very low boost, it will wipe-out the bottom end of the engine prematurely
#33
Speaking of the 3.8 bottom end, I don't like the idea of only 4 main bearings for 6 cylinders. According to the best picture I have seen of the crank, there are two throws between bearings. Not good for added power.
But, RIPP is having success with their setup. Time will tell.
#34
I have installed a 30hp shot that shoots directly into the intake tube. I notice a little gain in first and second gear full throttle acceleration but its such a small shot I dont notice it at higher speeds. NOS is designed to be used at about 3000rpm and higher so not good for off roading just straight drags. If used in large amounts and often it will wreck a stock engine, as will putting high boosts from superchargers and turbochargers. Hope this helps some.
#35
Lack of fuel is what kills engines that run nitrous. Plain and simple. A wet system with a dedicated fuel supply is the only way to relatively safely run it on the 3.8L. Even then it's mechanical limits are being pushed.
Having fuel is a major factor.
