Nitro sleeves + BFH = Successfully strengthening axles?
Old 06-07-2012, 05:48 PM
  #41
Beau's Avatar
Smooth end first
Old 07-02-2012, 01:53 PM
  #42
Happy Trails's Avatar
^^^^ What he said! Smooth end first. The ribbed end should be closest to your tires. Believe me, when the ribbed in starts going in, those last couple of inches are going to be a PIA to hammer in.
Old 11-25-2012, 03:04 PM
  #43
RIArmySGT's Avatar
I will be installing these in the next few weeks. Did you guy pull of your diff cover? Replace the inner axle seals? Thanks guys
Old 11-25-2012, 03:41 PM
  #44
Opalgem's Avatar
I'm installing a set as well in the next two weeks.
Old 11-25-2012, 03:45 PM
  #45
JK Forum Regional Rep
familytime's Avatar
[h=3]Nitro Sleeve Install Party (Day 2 with custom tools)Hey guys check this out,watch the video.We did 7 of these sleeves in 2 days[/h]
Old 11-25-2012, 04:22 PM
  #46
Dusty11's Avatar
I can see why these are no weld sleeves, they look tight. How's it handle and feel after the install?
Old 11-25-2012, 04:47 PM
  #47
familytime's Avatar
After these were installed, the front end felt firm.Sounds but everyone who had these installed said the same thing,including myself
Old 11-25-2012, 05:07 PM
  #48
scooby snacks's Avatar
Wow, the tool is key!! I watched the video without listening to the sound (didn't want to get busted... lol). I will watch and listen again. Hopefully it describes what's on the end of the tool that you guys built.
Old 11-25-2012, 05:17 PM
  #49
familytime's Avatar
It's the bearing driver with the wider end facing the sleeve.I stacked some washers that measured the same ID as the sleeve to keep from moving around.I built this tool because the first attempts using the required tool failed in a short time.
Old 11-26-2012, 04:13 AM
  #50
RIArmySGT's Avatar
Any chance you can post a pic of that tool, so i can show by buddy who works in the fab shop here in on the Army base i work at
Quick Reply: Nitro sleeves + BFH = Successfully strengthening axles?
