Nitro sleeves + BFH = Successfully strengthening axles?
#21
Same sleeve for the rear.Although a bend in the rear is less likely, strength never hurts. Especially the load on the rear going up hill. That is also where a alloy shaft helps a lot.
#24
#25
#26
I should have not responded from my phone so for that I apologize. The thickness of the frt and rear tube is the same only. No sleeve is offered for the rear and trusses are used to improve strength.
#28
Chris also sells upgraded frt shafts CA with bigger U-joints that work with the sleeves also.
#30
