Newbie help. 35" tire on rear tailgate?
Old 01-22-2012 | 06:30 AM
Biginboca's Avatar
Originally Posted by sclan
Here is what I did.
I had the same tire. I had some of the cheapie wheel spacers (not adapters with bolts) that I used to push the tire away from the tailgate.
This was just enough to allow me close the tailgate, but because of the toyos true size, it fit snug resting on the stock bumper (when I had one).
Had that for close to a year until I upgraded and I saw no signs of damage.
Cant remember the size of the spacer (1/8 in, 1/2 in??) so you may have to test fit a couple.
If 1/8" or 1/2" is all it takes he can probably just grab some washers from home depot and use those. A spare riding on the tailgate doesn't need a real wheel spacer, it sees no stress.
Old 01-22-2012 | 08:42 AM
OleBC's Avatar
You say 1/2 or 1/8th of an inch. I'm using a factory wheel. So wouldn't I need more then that because of the lake of offset?
Old 01-22-2012 | 09:08 AM
MNTN JK's Avatar
Just ordered the bump stops, thanks for the link.............
Old 01-22-2012 | 09:27 AM
JE8154's Avatar
I've had them backordered for about a month now. Go to the write up section and look for the tubing size you need to modify your factory bump stops until you get the daystar ones. I believe it's 1.5" OD if you go inside and 1.75"ID if you go outside the factory ones. But I'm not positive
Old 01-22-2012 | 11:40 AM
rickc309's Avatar
My 35 wore my top hinge in about 20K, had a rattle after that. It drove me nuts. I wouldn't hang another 35 on a stock carrier.
Old 01-28-2012 | 02:08 PM
sclan's Avatar
True...washers will meet the intent. I just happen to already have these laying around
Old 01-28-2012 | 02:12 PM
sclan's Avatar
Yes you will need more than that to make up the lack of back space. I had after market wheels with backspacing so it didn't take much.
And if that is the case, you'll be better off using the cheapie spacer vs a stack of washers.....x3.
Bottom line is that I mounted the spare out from the tailgate to be able to close it, but close enough to rest on the stock bumper.
Quick Reply: Newbie help. 35" tire on rear tailgate?
