Newbie gearing question
You already have a D44 in the rear... If you want to change the front axle to a D44 you can do that, but, why would you? I'm having my rig regeared next week and going with 5.13. I have a Rubi and installing 37" tires. So you might want to give more info on what your trying to achieve.
Well I was trying to go to 5.38 with 35" tires because it is an auto. Maybe I am incorrect in thinking that I need lower gearing then 5.13
Right now it has 4.88 on 33" tires and is ok not great
David
David
If that's all you wanna do... I would just regear to a 5.13 and it would work just fine. From there you can use a Superchip and dial in. But changing out the diff's is going to be way too much money and time for the return you get. I could be wrong here but I would think with 33" tires and a 4.88 your not going to see much of a change. Remember, we are talking about a 200 HP engine here.
You might want to beef up the axle if you go any bigger on the tires.
Open the Drivetrain faq's and start plugging numbers into the chart.
Auto, 5.13's, 35's = 2450rpm @ 70mph
Manual, 5.13's, 42's = 2450rpm @ 70mph
Auto, 5.38's, 35's = 2570rpm @ 70mph
5.38's would be the better choice, but it just depends on your budget and usage. Does your usage justify the cost of dropping in a front 44?
You are probably looking in the $1500-2000 range for a used rubi. Plus the labor to swap your ends over and install, plus the regear, plus gussets/sleeves/etc. If you can't find a used one, you are looking at around $3k for the axle, plus all the other costs. Or the better option would be to go straight to a PR44 for low-mid 4k's.
Personally, I would not spend the money to regear from 4.88 to 5.13. Wait until you find a great deal on a rubi, or until you make the jump to a PR or a D60.
