New wheels needed for lift kit?
Old 10-08-2014 | 12:24 PM
14Sport's Avatar
Improper installation is what you need to watch out for on spacers. I have been running them on my Corvette since 1986 with out a problem, even when I brought it to the track. Follow the instructions to a tee. Even removing the wheels and checking the spacers after 500 miles or whatever your brand recommends.
Old 10-08-2014 | 01:58 PM
GiggityGiggity's Avatar
very true.
I run custom milled spacers in the rear of my C5 Z06 so I could run a set of CCW's in C6 Base offset size. I had them made to my own specs being both hub and bore centric. Never ever had any issues.
Before I got my Fuels, I ran 275 70 18 duratracs with spidertrax spacers on stock wheels. They are also hub and bore centric, never had any issues.
As mentioned, install and torque properly, recheck after a few hundred miles. Make sure they are hub and bore centric (like spidertrax) and all will be fine. Or you can spend 3-4 times more and get new wheels.
Old 10-08-2014 | 02:06 PM
14Sport's Avatar
I did similar on my 500HP (built 400ci) 1988 Trans Am GTA. I ran 2" spacers so I could fit fourth gen wheels. Never a problem with that and I ran them for 4 years before I sold it.
Old 10-13-2014 | 10:11 AM
TexasJeep2009's Avatar
Just an update. Everything turned out just fine!Click image for larger version
ID:	579681Click image for larger version
ID:	579682 no rubbing any drives smoothly
Old 10-13-2014 | 10:19 AM
14Sport's Avatar
Looks good. I thought you said you had stock wheels?
Old 10-13-2014 | 12:18 PM
I think the wheels I have are the same as stock.
Old 10-13-2014 | 12:29 PM
14Sport's Avatar
Did you measure the backspacing and if so, was it 6.25"?
Edit: If you have extended rear sway bar links and 6.25" of backspacing I sure would like to see a picture showing the wheel and the end link taken directly from the rear.
Old 10-13-2014 | 03:06 PM
espi's Avatar
Stock wheels are actually 6" backspace as they are 7.5" with 45mm offset.
Here are Teraflex extended rear links with 285/70r17 on 8.5" wheel with 5.2" backspace.
Here are the links mounted inward.
I ended up not using them at all and are just taking up space in my garage.
Sent from my SM-G900V using Tapatalk
Old 10-13-2014 | 03:52 PM
14Sport's Avatar
That's exactly what I expected to see. And I never measured mine before I dumped them but am pretty sure the backspacing is 6.25". A quick search turned up these.
Wheel and Tire FAQS
https://answers.yahoo.com/question/i...3094459AAlSsyI
My Jeep Wrangler JK: Largest Tires Can Fit On Stock JK Wranglers Without A Lift
So if those pics are from 5.2" of backspacing, just imagine where wheels moved another 1"+ inboard would put the links.
Maybe I'm missing something. Sorry if I am off base here.
Old 10-13-2014 | 04:51 PM
espi's Avatar
Wheel and Tire FAQS
The offset stamped into the wheel is 44.45.
