New Trail Master 3" Lift
So I was on Quadratec today just surfing the new stuff that came out in this summers catalog. I saw this 3" lift kit by Trail Master for $320.00
Here is the link
hxxp://quadratec.com/products/16106_201.htm
Just wondering if anyone has purchased this. What the installation is like. And if it is worth getting. I don't do a lot of rocks. Just mud beach and logging roads, but putting 34" DuraTracs on so need a lift. For $320 it looks nice.
Thanks
Here is the link
Thanks
Trail Master
If you are already running a 2.5 inch bb, why would you spend that kind of money for another 1/2 inch of budget boost? You need to jump on up to a spring boost if you are going to spend the bucks. Just my 2 cents. When I get the money saved up I am going to go with a 4 inch teraflex. I reread your post and you dont have the Teraflex bb checked off. My bad. I think I would go with the Teraflex unit myself.
It's a BB with extras.
No caster correction, and the same front driveshaft issues as everyone else with a lifted auto...
For the installation, look at any of the write-ups in the suspension write-ups area. Same steps, whether it's a coil or spacer lift. Then open the DIY alignment one to adjust that front adj trackbar.
What front drive shaft problems? I thought if you stayed in the 2.5-3" range there were no drive shaft issues?
https://www.jk-forum.com/forums/show...vs.-Skid-plate
You will also want to keep an eye on the rzeppa (tcase end of the shaft). It will be pinched from the angle and may start spitting grease. They are not serviceable, so once the rzeppa or a torn boot start losing grease, it's just a matter of time. a few people have indicated that they are manually greasing the shaft to prolong the life, but...
Flex it and check the clearance after the install. If it is anywhere even close to the crossmember skid or the corner of the tranny pan, see post 6 in this thread:
Depends on how much actual downtravel you have. People that disconnect and have longer travel shocks are more likely to run into contact issues than people than don't disconnect and have shorter shocks. Best advice is to flex and check
Also make sure your front axle is centered. If it is off to the passenger side to far, the driveshaft is moved closer to the tranny pan.
Another quick question. I know a lot of people on here run Wheel Spacers, but I was talking to a couple friends from PA and they have driving jeeps their whole life and told me to stay away from wheel spacers because of the tendency to break which would screw you. Now is that them talking about older technology and not knowing the newer wheel spacers strengths or is it personal preference?
