new trac bar needed
Old 06-29-2016 | 03:08 PM
  #31
mds22's Avatar
Originally Posted by DunnyBunny
That's called dedication to bug neighbors to prove a point. Lol.
Thank you, I thought so. More curious than anything.
Old 06-29-2016 | 03:15 PM
  #32
The Black Jeep's Avatar
Originally Posted by mds22
Good thing or not they all do and cause no problem with steering or safety.
I said it is "not needed" and "plenty strong"
don't think I ever said "exactly the same" or "no difference"
You are happy with your purchase and how you spent your money, good for you. Doesn't mean it is the only recommendation that is valid.
I'll stick to my statement, "stock TB is plenty strong and unless you have worn out bushings or need to re-center your axle, there is NO NEED to run any other TB than a stock one."
That's an opinion
And I choose to disagree
To the OP after I put my jks track bar on replaced from stock there was a huge difference in my steering I believe it was because when the thin track bars like the stock one flexes that is actually the axle moving from center to right or left that is all the track bar does is hold the axle to the frame and if they don't flex the axle doesn't move side to side in relation to the frame
Old 06-29-2016 | 07:32 PM
  #33
mds22's Avatar
Originally Posted by The Black Jeep
That's an opinion And I choose to disagree To the OP after I put my jks track bar on replaced from stock there was a huge difference in my steering I believe it was because when the thin track bars like the stock one flexes that is actually the axle moving from center to right or left that is all the track bar does is hold the axle to the frame and if they don't flex the axle doesn't move side to side in relation to the frame
To the op for the last year I used a stock track bar with my EVO leveling kit and 35" tires, I recently added a Synergy Adj track bar to center my axle from adding 2.5" coils.... ZERO difference in steering.
The same result on my last JK when I had a RK adj TB, and then went back to a stock TB after flipping my drag ink. ZERO difference.
My jeep is a high mileage DD and I Wheel every chance I get.
Old 06-30-2016 | 01:48 AM
  #34
GunDude's Avatar
Rusty's adj. track bar $130
Quick Reply: new trac bar needed
