New RubiCrawler! Lower your crawl ratio!
This is sweet! Check out the crawl ratio at the bottom of the page. I put a 4:1 gear set in my TJ and it was a pain (and loud too). This appears to be a very simple install. Guys without a Rubi no longer have to envy a 4:1 transfer case, this will do the job.
42RLE EVOLVED, LOW GEARING MODULE THAT REQUIRES NO DRIVELINE MODIFICATIONS
This units fits Jeep's 2003 to 2009 with the 42RLE automatic overdrive
Units available Summer 2009. Order today to get your place in line.
Advance Adapters is proud to introduce the RubiCrawler (Rubicrawler).
This new reduction unit replaces the stock 42RLE tailhousing with a 6 gear planetary featuring a 2.72 low range. This is a true bolt-in doubler that couples to the stock Jeep transfer case or an existing Atlas 2 speed.
The Jeep 42RLE transmission has a stock tailhousing that is approximately 7” long. The rear output shaft in this tailhousing is actually a spud shaft, that pulls out of the rear of the main transmission case and leaves the stock output shaft in place. The RubiCrawler has a custom input gear that couples to this transmission main shaft with no modifications to the transmission. This new input gear drives 6 planetary gears that gives the RubiCrawler the 2.72:1 reduction. The Rubi-Crawler’s housing is exactly the same length as the stock tailhousing and includes a new 23 spline output shaft that couples the rear of the RubiCrawler to the stock transfer case, leaving everything in the stock location.
The RubiCrawler’s shifting mechanism utilizes push pull cable technology for a smooth and easy shift. The universal cable shifter is included with the purchase of your RubiCrawler. (The universal shifter should be used if your vehicle is equiped with an Atlas transfer case)
We also offer a twin stick cable shifter for the Jeeps. These kits are designed to fit the stock TJ and JK consoles.
The Jeep TJ's switches the standard hard linkage to a new cable installation. We have designed a twin stick shifter that comes through the stock console for a clean installation that operates the RubiCrawler and the stock NP231 or NP241 transfer case.
The twin stick JK shifter also provides a twin stick shifter through the stock console, this kit retains the stock transfer case cable with the addition of the new RubiCrawler cable.
These shifters are a additional charge but are the best suited for most installations. (Note, if your vehicle does not have a stock transfer case, The universal shifter should be used.)
Ratio possibilities with a -
Stock New Process 231/241 are a 2.72:1 and a 7.40:1
Stock NP Rocktrac are a 2.72:1, 4.0:1 and a 10.44:1
Atlas 2.0 are 2.0:1, 2.72:1 and a 5.44:1
Atlas 3.0 are 2.72:1, 3.0:1 and a 8.16:1
Atlas 3.8 are 2.72:1, 3.8:1 and a 10.44:1
Atlas 4.3 are 2.72:1, 4.3:1 and a 11.70:1
Atlas 5.0 are 2.72:1, 5.0:1 and a 13.60:1
http://advanceadapters.com/product/4...overdrive.html
http://www.rubicrawler.com/blog/
