New to the jeep life.. I need help, bump steer
If you reverted to 2.5" springs, your caster would still be a bit low....probably around 3.3° guestimating, but not as bad. It would still be advisable to do some caster correction, be it $100 control arm brackets or lower adjustable arms that you could make a bit longer than stock. The steering angle would flatten out some as a byproduct of bringing the jeep down. If the DS boot has not ripped yet the life would be extended, but no guarantees there. As noted above, it can happen at 2.5" too, but it's not as much of a given as it is at 3.5".
Unfortunately, there's nothing inexpensive about modded vehicles. That is just kinda what you get into when heading down that path. Almost everything is interconnected and you can't touch one thing without having an impact on various other things.
I dug up one of my favorite images for you.....lol...I take no credit in its creation -
cidd (02-05-2023)
Thank y’all for the replies. I looked at the pitman arm and it seems to be stock. I have chased this bump steer until I’m blue in the face. I really appreciate the insight. All of the steering components are less than a month old, so it would be hard to convince the wife I need to redo it again. If I were to drop it down with 2.5” springs, would I eliminate the need to purchase adjustable control arms and aftermarket DS. I just want it to drive right with 35s on it and be ok I’m the woods.
https://www.extremeterrain.com/teraf...t-0718-jk.html (although you could find them cheaper on Amazon)
https://www.northridge4x4.com/part/d...r-draglink-end (RC makes one cheaper but, your call)
35's can be heavy and will flex the drag link enough to make you sweat.
