New-ish JK owner....need to get a jack
I need to get a jack for my JK...35 inch tires and a 4" lift. If I have blowout or flat, I need to repair. Any suggestions o the size jack I need? Thanks!
![FJOTM Winner](https://i.ibb.co/FgFLpFN/Untitled-1.jpg)
The stock jack and a 4*4" chunk of wood works fine. If you insist on something more expensive then arb sells a base that you can use under your factory jack.
The jack only has to get the axle 18" off of the ground so you don't honestly need anything extravagant.
I use a 4x4 block as a base also.
Never had a problem with the stock scissor jack, just always thought it looked flimsy, so picked up a cheap 12 ton bottle jack one day while wandering around harbor freight. Does the job just fine.
