New Heim End or New Trackbar? (RockKrawler)
Factory hole is supposed to be a loose 9/16" (after working with artec on their first revision trackbar bracket they found the Chrysler drawing has a 5/8" hole). Factory bolt is 14mm.... not the same.
This x2 i use heim joins on my track bar, control arms,drag link, and tie rod. I had a track bar one go out within a month....I safety washer what i can and carry spares incase.
I'm pretty sure the heim I have is shot. I have a new one in the mail from RK. The joint klunks back and fourth when I followed then plan man diagnostic videos.
I also learned the hard way that the tie rod end of the steering damper is not the place to detach the damper from... That rubber sleeve did not one to go back on. I had quite a time getting it back on...
For that north ridge kit posted, the washers have to be welded to every bolt hole? I have a mig welder but I'm not good enough to put it to my jeep...
