New gear itch...
New gear itch...
I have a 2009 Rubicon. I put a 3" lift and 35" tires on a week after I bought it and never looked back.
I have been seeing a lot of postings on gears lately. Would chnaging the gears with my set up may a big difference?
Gears are the single biggest performance improvement you can make when going to bigger tires. Don't know if you have looked at superchargers at all, but even Ripp suggests re-gearing before buying one of their own products. That right there says a lot...
You have 4.10's. With a manual and 35's, 4.88's are popular. But, check any of the thousands of other gearing threads for more opinions. And you should also open the Drivetrain FAQ's and check the charts.
I have 35's on mine and just installed my own gears. I got 4:88. I have a 2dr 6 speed. If you have an auto go with either 4:88 or 5:13 depending on your driving style or if you in the future going to 37" tires. I believe that you have 4:10 gears stock.
I actually just tripped across a great gearing thread here so I have a better understanding of where I am and where the sweet spot is.
I do have 4.10's with the Rubicon, and I should have said in my first post that it's a manual. So based on the grid here (https://www.jk-forum.com/forums/jk-write-ups-39/gearing-82262/) I would only go up to 4.56's.
Seems like a lot of work to move up a single gear step. Now that I have given everyone the full picture does going from 4.10's to 4.56's make sense?
I do have 4.10's with the Rubicon, and I should have said in my first post that it's a manual. So based on the grid here (https://www.jk-forum.com/forums/showthread.php?t=82262) I would only go up to 4.56's.
Best advice would be to listen to the thousands of people that have already geared their manuals. Browse through more threads, and you'll see that 4.88 is the gear ratio of choice for that setup. With a price tag in the $1000-$1500 range, it isn't something you'll want to do twice.
Amen to that!
What happens to the feel of the Jeep if I go too high? I realize too low limits power and I get that. But I can't picture what going too much would do....
It might, if you could actually find them...
I am still in the break in period but I am impressed with the 4:88 set up.
It won't take long before your 35s start looking like 33s I say 5:13s and call it a day and not have to worry when you order your next set of tires which may be a lil bigger, give Dave a call at Northridge4x4 he'll take of u....
