New Driveshafts? When?
Thanks!
Thanks! I really appreciate all the info. I went ahead an ordered both driveshafts from the drive shaft superstore. In about a couple of weeks I'm going to have a huge project in my hands when I install the TF 3" lift kit, superlift rockrunner control arms(all 8,front and rear), TF front adj track bar, front and rear driveshafts, Procomp alloy wheels 17X9 7189 model and Cooper STT 35" tires Hopefully I can get this done with a friend of mine in a weekend. I'll post pics of the process of my JK Rubicon's transformation
Once again thank you to all you guys
JK-Forum Founder
if you ordered your 1350 shaft with the flange as opposed to the yoke, you will get some contact with the gas tank skid but it's not that big of a deal. you will mostly get it when flexing on the trail and that's it. when i was running this setup, it just wore a dent in the skid and when it finally got deep enough, i wasn't getting any more contact.
Thank you!
so... is changing out this yoke such a PITA as it sounds?
are you guys doing it yourself or having it done at a shop?
something about my ass and 200lbs of tork just sounds like trouble.
and this part may sound really stupid, but when i first started research on "these" drive shafts, the flanges and replacing this CV crap... i could have sworn i read something about having to cut an inch or so off of the out put shaft on the TC..??? WTF...
i think i have already lost what i had left of my mind
JK-Forum Founder
getting the pinion nut off is a PITA if you don't have an impact wrench. however, the hardest part of the job is re-installing the pinion nut WITHOUT crushing the crush sleeve more or installing it too loose. if you have a high end inch lbs. torque wrench that can measure to the inch, there is a way to do this right but a torque wrench like this can cost $200-$300. having said that, you can try marking the pinion nut and be mindful of it coming off. when reinstalling it, use red lock tite and try to make sure to reinstall the nut to where it was before or just a hair more.
