new driveshafts. need adj control arms??
1 Post
well basically what the titl says. i plan on getting the aev 3.5 lift sometime this year, im not going to get new shafts soon but just in case i wreck the factory shaft what control arms it any do i need to install with new driveshafts?
im thinking of going with terraflex flex arms to replace the front lower cam bolts but i am looking for the ones with the best bushings. i dont flex on rocks much i just want good solid stuff that will last. what other makes would you recomend?
and i think im gonna go tom woods if i have to replace them
thanks
thanks
I like my teraflex arms a lot. you can't go wrong with them. It would likely be a good Idea if you can afford front lowers to adjust caster, and rear uppers to adjust pinion angle. In the front though your pinion angle will probably be ok without adjustment, but the crappy caster will make the jeep drive darty and wander a lot IMO.
