New driveshaft
Old 05-09-2011, 06:28 PM
JK-jeepit's Avatar
Originally Posted by nmwranglerx
Man if you haven't had a problem for 10,000 miles maybe you won't (lol). I had a torn driveshaft boot within a month of installing my 2.5 in lift and also knocked the seal on my tranny pan. With my upgraded 4 inch lift, it's now slinging grease from where the front ds connects with the transfer case. Do you have a manual or auto? That makes a difference.
I also tore my drive shaft boot 2 months after the installation of a 2.5 lift.
thinking of replacing it with the coast 1310
Old 05-10-2011, 03:47 PM
weebus's Avatar
Default driveshaft
mine didnt tear the boot till i disconnected the sway bar for a tough trail with swaybar connected i had no tearing/hitting of the trans
Old 05-10-2011, 04:00 PM
nthinuf's Avatar
Originally Posted by GB94
I have an auto and I can here it squeaking but I don't really flex my suspension I just go mudding. How do I know if it's going bad so it doesn't break while off roadin
Crawl underneath and look at the joints at the tcase end of both driveshafts. You are looking for grease coming out of the little boot, and/or a ring of grease on the undercarriage above the joint. If one of those joints has lost enough grease to start making noise, you'll will want to replace that shaft.
---> You do NOT want to be on the freeway when a joint seizes <---
Old 05-11-2011, 02:11 PM
GB94's Avatar
I don't see any but how's that possible with10000 miles on the lift
Old 05-11-2011, 02:27 PM
mkjeep's Avatar
Geez guys, that stupid spline boot that gets ripped off isn't near as important as the rzeppa joints.
Old 05-11-2011, 02:28 PM
mkjeep's Avatar
Anything is possible, up to you whether you deal with it or not.
Old 05-11-2011, 02:48 PM
nthinuf's Avatar
I have been running a 4 inch lift with 35s for 10,000+ miles and have had no problems. Is it likely that I will ever need to replace them?
So no problems? Or there is a problem and a driveshaft is making noise?
Lots of factors involved, so you can't just put a certain mileage value to it. 2doors have short rear shafts. Add 4 inches of lift, and the angles on that shaft are fairly steep. Regardless of flexing offroad, these angles cause the little boot in the rzeppa to be in a constant state of 'pinch', which will eventually wear through it. How soon? Anyones guess. But at that height, you should plan on it happening.
Old 05-11-2011, 04:59 PM
4WHLN's Avatar
I tore my boot 3 years ago after installing my 2.5 tf lift and have had no problems yet. I may be lucky.
Old 05-11-2011, 06:04 PM
JCS78's Avatar
Can you replace the front shaft with an aftermarket one without replacing the rear?
Old 05-11-2011, 06:18 PM
mkjeep's Avatar
Yes....
Quick Reply: New driveshaft
