New driveshaft
Man if you haven't had a problem for 10,000 miles maybe you won't (lol). I had a torn driveshaft boot within a month of installing my 2.5 in lift and also knocked the seal on my tranny pan. With my upgraded 4 inch lift, it's now slinging grease from where the front ds connects with the transfer case. Do you have a manual or auto? That makes a difference.
thinking of replacing it with the coast 1310
---> You do NOT want to be on the freeway when a joint seizes <---
Originally Posted by nthinuf
Crawl underneath and look at the joints at the tcase end of both driveshafts. You are looking for grease coming out of the little boot, and/or a ring of grease on the undercarriage above the joint. If one of those joints has lost enough grease to start making noise, you'll will want to replace that shaft.
Lots of factors involved, so you can't just put a certain mileage value to it. 2doors have short rear shafts. Add 4 inches of lift, and the angles on that shaft are fairly steep. Regardless of flexing offroad, these angles cause the little boot in the rzeppa to be in a constant state of 'pinch', which will eventually wear through it. How soon? Anyones guess. But at that height, you should plan on it happening.
