New Bumper, Winch On Order--What Would You Do?
I know you said you don't want to go 17's, but if you only want to go with 32's, then I'd seriously look into a set of Rubi take offs.
I siped ours with 2500 miles on them and they've now got over 35k on them and still have over half tread left. I've been quite happy with them.
Just a thought.
Just a thought.
Actually, the SR-A's on mine are 32's from the factory (255/75/17's)
Any rim up to 8" can handle a tire wider than you would mount...so a 10" rim is just too wide for the tires you're talking about...
Unless you are talking about monster WIDE 32" tires, like 32x14.5's or something.
The stock 7.5" wide rims take even 13" tires in stride for offroading...and 12.5's are commonly used....even on 7" rims.
So - the stock backspacing is 6.25", and can handle up to a 285 mm section width (11.5") tire with out much trouble...
The stock tires come as 32's....so upping to 33's is easy, they only stick out another 0.5".
IE: A 33x11.5 tire IS a stock size with a bit more width....and, it would fit on any rim that had less than 6" of BS very easily.
Thanks, everyone, for your comments; I really do appreciate them! So here's what I'm currently thinking:
The Cragar 352 black street lock steel wheels. 16x8. 4.0 inch backspacing.
The Dick Cepek Radial F-C II tire. 33.0 inch, LT285/75R16, 11.30 tread width.
I think that tire fits my need for street/wet weather performance, while giving me a boost in off-road performance. Anyone foresee any clearance problems with this combination? Any other thoughts? Again, I appreciate everyone's input!
Edit: I have the 4:10 rear end (07 trailer pkg).
if i was in your place i would go with tires keep the stock rims they look good and if you feel the need to be differnt have them powder coated take the 5-6 hundred and put it twords skid plate/under armor
Well, I did it. I've got new Dick Cepek FC-IIs--LT285/75R16s on order. These are 33" tires. I figured that could let me hold off on lifting the JK for a while. Will mount these on ProComp 7089 16x8 wheels. After looking at the ProComp equivalent of the Cragar wheels I'd originally selected (see image above), I decided they didn't appeal to me all that much. Basically, they look like the Soft 8s with a narrow metal band bolted to the inside lip of the wheel inset, then with some cadmium-plated bolts tacked on to give the appearance of a bead lock. Both my son and I agreed they looked great in the pic's--but not so great in real life (I'm trying to be nice here, just in case someone else has bought these ). So, we really like the 7089s, which are an all flat-black alloy wheel. Anyway, the new wheels, tires will be mounted and on the JK next Monday afternoon.
I may still be able to spring for a little more. I'm thinking Lightforce lights for the new Shrockworks bumper. And I'm thinking of perhaps a new rear bumper. Any suggestions? I want a swing-out tire carrier, and I'd really like to keep the stock trailer hitch. Jerry can and High Lift mounts would be really nice, too. I like the Shrockworks rear bumper because of the back-up lights (a real problem for me in one particular place where the road I must back up is dark, narrow, winding and lined with trees). But I don't know if that will do all that I want it to. Ideas, anyone?
New Tires and Wheels
Okay, I originally thought I was going to get the Cragar Street Beadlocks. Well, I went to the local Four Wheel Parts and looked at a similar ProComp wheel. And I really didn't like it. As I've said elsewhere, I generally don't like "fake" things (plastic wood grain finish, gold plating, etc) and the street beadlocks reinforce that. Looked great in the images, but not so great in real life. So, I bought some ProComp 7089s. Those are Dick Cepek FC-IIs on there--33". There's a Rough Country 2.5" BB and shocks on order. Here are the images:
The "JEEP" on the front will be removed when the weather warms up:
What a difference in appearance:
I'm still waiting on the Shrockworks front bumper. I'm starting to get antsy.
