nervous about adding a snorkel
Old 03-21-2012 | 09:06 AM
JeepingNet's Avatar
I installed the AEV snorkel and the cutting is really easy. They provided a template that is really easy to use. I drilled a small pilot hole to ensure I was on the spot.
Plus there is a bit of room if you don't get it exact. It doesn't need to be one the dot exactly because a ring goes over your cut to hide it.
The only issue I ran into was the block of wood I was uses to prop the hood open vibrated out of place. Make sure it is secure.
Old 03-21-2012 | 10:46 AM
p1llar's Avatar
Thanks for the tips.
Quick Reply: nervous about adding a snorkel
