Needing a lift.
Needing a lift.
I have a 2007 4 door and I recently bought a set of 37" tires for it because I found a great deal, anyway, how much lift will be needed to fit these and who makes a good kit? Also will I need to regear?
You truly want at least 4" of lift to run those without rubbing. You could do all suspension or do a smaller lift with flat fenders or even a body lift. And yes you will want to regear running 37's
just a leveling kit will fit.
and spidertrax spacers if youre using stock rims.
Attachment 239762Attachment 239763
Originally Posted by Cusey Chatham
Ok ludski do you have a leveling kit or 3.5" suspension kit I'm confused. I want something that will give me a good amount of articulation.
To run 37s I suggest a 3" lift and flat fenders as a minimum. I highly suggest you read Planman's thread on running 37's. All your questions can be answered. He is the Jedi for LCG and big tires. Worked for me.
Ok so I did quite a bit of research last night. I think my 3 leading kits are:
AEV 3.5"
Rock Krawler 3.5"
Or Clayton 3.5"
I'm very much liking the Clayton mainly they are located in Connecticut and I spoke with them yesterday and I am going to go chech out their facility.
Is anyone running a Clayton premium lift kit? How is it for on road use?
AEV 3.5"
Rock Krawler 3.5"
Or Clayton 3.5"
