needed with TF 2.5 coil lift??????
Old 02-28-2009, 07:09 PM
08JKJohn's Avatar
Default needed with TF 2.5 coil lift??????
Ok guys, yes i have searched but am still confused. I am ordering the TF 2.5 coil lift and putting on 35s. Are the adj. front lowers and adj. front track bar necessary, needed or just usefull???? I want to order everything needed that is not in the kit. Just make it easy for me and tell me what to order lol. Thanks for your imput
Old 02-28-2009, 08:09 PM
doc307's Avatar
I am running the TF 2.5 coil lift with shocks and 35's. I did end up going back and ordering an adjustable front trackbar but still use the rear bracket that comes with the kit. My axle was off center a little and I did it for looks. Once installed it did make a difference in the handling, much better. I wouldn't say its necessary but it helped mine. I have not changed out any other parts like control arms etc.
Old 03-01-2009, 06:07 AM
07Rubi2dr's Avatar
I've done the lift and haven't changed anything, no probems for me, axels are only slightly off center
Old 03-01-2009, 06:13 AM
REL1203's Avatar
Any rubbing issues with only 2.5" and 35"s?
Old 03-01-2009, 06:15 AM
sgmrock's Avatar
No, it doesn't even get close!
Old 03-01-2009, 06:17 AM
sgmrock's Avatar
X2...This is exactly how I did it. I have had mine on for 1.5 years now.
doc307's Avatar
I get some fender rubbing at full stuff but I am probably going to trim the fenders anyway. Nothing too bad
Old 03-01-2009, 09:00 AM
MD5
MD5's Avatar
I'm also interested in this lift. Any rubbing issue with the stock 17" wheel and tyre ?
Old 03-01-2009, 09:27 AM
RUBI67's Avatar
Until which lift can u run the stock shocks without extensions?
Can you run a 2,5" lift kit with the stock brake lines, from which lift height do u need to extend them?
Old 03-01-2009, 04:50 PM
doc307's Avatar
I'm still running the stock brake lines, the TF does come with a bracket for them. Looking at some of my pics while flexing I would be hestitant to go any taller without extensions, they were pretty tight
Quick Reply: needed with TF 2.5 coil lift??????
