In need of urgent help! Tie rod end removal??
Old 03-09-2014, 07:13 PM
ronjenx's Avatar
Originally Posted by AXIS
Alright, I suppose Ill look at ordering an aftermarket one.
Are there any that will use the same ends as OEM so I can use the Moog ends I just bought instead of getting new ones too?
I am curious how the Moog end would fasten to the OEM rod, since the OEM end is crimped on and not intended to be replaced separately.
Old 03-09-2014, 07:23 PM
TheDirtman's Avatar
If you can weld I would recommend the ruff stuff kit. They are on sale 15% thru tomorrow midnight as well. Only like $125
"daylight" is the code for 15% off
http://www.ruffstuffspecialties.com/...g/TREOFFK.html
AXIS's Avatar
I wonder the same. During my original searching I read that I should order both moog ends if I want to replace the worn oem ones. Now It looks like ive got $85s of ends with no rod to put them on.
Old 03-09-2014, 09:18 PM
mistasparkl's Avatar
I believe Rock Krawler tie rods use OEM tie rod ends.
Old 03-10-2014, 05:44 AM
RedRubiMan's Avatar
Check out this one: It's made by Rock Krawler and designed to use OEM style tie rod ends.
Rock Krawler JK Heavy Duty Pro Tie Rod (RKJK_HDTIEROD)
Old 03-10-2014, 08:53 AM
AXIS's Avatar
The RK one uses the drag link pitman arm end which isnt the same as the stock tie rod ends. I suppose I will have to go with something completely new.
Whats is the cheapest tie rod that you guys would recommend? I dont feel the need to spend $500 on a tie rod but at the same time if Im going to upgrade I dont want junk.
The welding your own route seems nice but I HAVE to get a tie rod by friday so I can get it installed this weekend. I wouldnt be able to get it welded by then
Old 03-10-2014, 08:55 AM
TheDirtman's Avatar
If you have to buy a tie rod ready to go I would get the synergy.
Old 03-10-2014, 09:22 AM
AXIS's Avatar
That was my thought as well. I had a vendor contact me offering a deal on a Synergy tie rod and drag link a while back so Im trying to see if that offer is still on the table.
On a side note, I cant wait to get it all installed because these wheels will be awesome!
Quick Reply: In need of urgent help! Tie rod end removal??
