In need of urgent help! Tie rod end removal??
I am curious how the Moog end would fasten to the OEM rod, since the OEM end is crimped on and not intended to be replaced separately.
![FJOTM Winner](https://i.ibb.co/FgFLpFN/Untitled-1.jpg)
If you can weld I would recommend the ruff stuff kit. They are on sale 15% thru tomorrow midnight as well. Only like $125
"daylight" is the code for 15% off
http://www.ruffstuffspecialties.com/...g/TREOFFK.html
I wonder the same. During my original searching I read that I should order both moog ends if I want to replace the worn oem ones. Now It looks like ive got $85s of ends with no rod to put them on.
Check out this one: It's made by Rock Krawler and designed to use OEM style tie rod ends.
Rock Krawler JK Heavy Duty Pro Tie Rod (RKJK_HDTIEROD)
The RK one uses the drag link pitman arm end which isnt the same as the stock tie rod ends. I suppose I will have to go with something completely new.
Whats is the cheapest tie rod that you guys would recommend? I dont feel the need to spend $500 on a tie rod but at the same time if Im going to upgrade I dont want junk.
The welding your own route seems nice but I HAVE to get a tie rod by friday so I can get it installed this weekend. I wouldnt be able to get it welded by then
That was my thought as well. I had a vendor contact me offering a deal on a Synergy tie rod and drag link a while back so Im trying to see if that offer is still on the table.
On a side note, I cant wait to get it all installed because these wheels will be awesome!
![](https://fbcdn-sphotos-a-a.akamaihd.net/hphotos-ak-ash3/t31/1962017_10202310872512125_772481210_o.jpg)
