Need urgent help - Spidertrax spacer bonded to rotor
Howdy!
I'm the middle of exchanging my Jeep's rotors but the spacers are stuck.
Already tried a rubber mallet, didn't move.
Tried to wedge a metal wedge between spacer and rotor with a hammer. It didn't move also.
Sprayed WD40 over the seam and inside but also did not help.
Any hints?
Thanks in advance!
Any hints?
Thanks in advance!
Howdy!
Any hints?
Thanks in advance!
Any hints?
Thanks in advance!
Thanks! I applied more this time. Last time I just applied very few. It came out easily once I headed it up with the torch.
Finished installing and did a quick ride around the neighborhood to set the new pads and let them dig into the new rotor.
Everything seems fine.
I took photos of the steps and did a quick write up in case other forum members run into similar snags while changing the rotors and pads.
https://www.jk-forum.com/forums/jk-w...8/#post4156808
Thanks a lot again! Cheers!
