Need Tech advice on a Teraflex 1.5 Performance spring level kit.
Hi all,
This is my first post on this board, I have a 2013 Sahara Unlimited that I want to lift with a Teraflex 1.5 Performance spring kit and I have a couple of questions for the guys that are running this kit. I have read all the post regarding this lift but there is no mention of issues maintaing proper castor and pinion angle, So that is my first question, does this kit maintain the factory geometry, if not what is the best way to achieve this, will the AEV brackets work or would it be better to go to an adjustable UCA. This is my DD and I do get it in the dirt quite a bit, mostly on bumpy fire roads and the snow, no rock crawling so I do not need a massive lift or tires just want her level with good road manners.
I installed this kit and then put my 13 jku on the alignment rack and it was all within spec. I can tell you save some time and install an inch spacer in the back as it will be squatting otherwise. Every body I know has had the same issue. TF knows it is an issue and will give you a set of spacers after it sags. They should include them first. Mine sagged in less then a month. I liked the kit but decided to go another route on my 14 jkur because I did not want to deal with the sagging. I will say it handled great on and off road.
Jadmt,
Thanks for the info regarding the spacer, sounds like good advice. Are you sporting a diff bumper with a winch or do you just have the stock bumper.
I don't have a better side view, his is the silver mine is the white. same equip except mine has 2" AEV lift and side by side in person does sit higher and is level.
