Need some quick trqck bar help!!!
Hope this vid works:
http://magis.to/fycqWQRTGEIsP3kGDmEwCX17?l=vsm&o=i&c=c
Made this vid with a free iPad app so not sure if it'll work. Been having a hard time tracking down by wandering issue. I have quite a bid of movement and axle shift when dry steering in my garage. The axle side bushing rally squishes a lot and moves as you can see in the end of the vid. Is this more than usual??? With both ends moving as much as they are, is this my problem?
Thanks!!!
Thanks!!!
After I installed my lift about a year ago, I took it in to my local shop and they confirmed it was around 4.5*. I haven't messed with it so it should be the same. It so only recently started driving like this - the only thing I changed was the northridge bolt kit.
I'd contact the manufacturer of your track bar and show them your video.
It seems a little excessive to me but I run a Rock Krawler TB that has a Heim type joint on one end and has a massive bushing (flex joint) on the other....it doesn't flex like that one.
