Need Some Info
Need Some Info
Wanting to upgrade to a 6 inch lift and 40's, What will be required.....i have a 09 x with a procomp stage 2 kit .......i know i need gears.....will i need a new front carrier?.......i know i need drivshafts---mine are clunking now with a 4 inch lift .....what else will i need and what do you guys suggest
Axle reinforcement -- D44's minimum, EVO c-gussets, EVO axle reinforcing inner tubes, maybe stronger u-joints, maybe stronger inner axle shafts. Everything else is just like any other lift/tire -- control arms, track bars, brake lines, driveshafts, gears, coils, drop pitman arm etc.
I would focus on strenghting the axles.
Read through the Suspension and Drivetrain Faq's
https://www.jk-forum.com/forums/modified-jk-tech-2/modified-tech-faq-answers-questions-every-newbie-has-18617/
Use the info here:
Q: What are all the components that I will need with a 4" lift?
as the basis for your 6" build.
(I have not looked into longarm kits, but I would assume that they are pretty complete for the hefty price tags involved)
Plan on as many axle upgrades as you can afford.
Plan on chopping your fenders or going to flats.
And plan on destroying that D30 and upgrading to a D60...
The folks at SLC seem to be pretty good at answering questions and walking through builds, may be worth your time to call or message them. Same with the TeraFlex and Northridge sponsors. Plenty of resources available to help ya...
THANKS FOR SOME OF THE INFO ........iM LOOKING ON WHAT I SHOULD START WITH AS IM NOT GOING TO BE ABLE TO SO THIS ALL AT ONCE
MY THOUGHTS ARE:
1 GO WITH NEW GEARS - I CAN RUN THEM WITH MY SET UP
2 GET DRIVE SHAFTS - I NEED THEM NOW - ANY SUGGESTIONS ON WHAT TO GET
3. AXLE UPGRADES- NEED SOME MORE INFO ON THIS
4. LIFT - SHOULD I ADD TO MINE OR GO ALL NEW
ANY THING ELSE YOU GUYS THINK I SHOILD TROW IN THERE .....MABE SOMEONE WHO HAS DONE SOMTHING LIKE THIS ( NOT ALL AT ONCE )
I'M PRETTY MACHANICALLY INCLINE SO I WILL BE DUING EVERYTHING MYSELF WITH THE HELP OF SOME FRIENDS
MY THOUGHTS ARE:
Yep, 40's on a D30 with 5.13's is just asking for trouble. Spend the axle 'beefing up' money on a new D60, or at least a built 44. (instead of throwing money into gears/gussets/alloys/sleeves/truss, blowing it up anyway, and then buying the axle you should have started with.)
Check post #5 here. May as well read the whole thread while you're at it. (D44 with chromoly shafts)
https://www.jk-forum.com/forums/modified-jk-tech-2/37s-d30s-105661/
If you're set on a D30 upgrade, try:
https://www.jk-forum.com/forums/show...ighlight=build
There are a bunch of axle build-up threads, just do some searching. (there was one in particular, title was something like "my cute little d44 build-up" or something similar. Good info, but didn't locate it)
For the driveshafts, they'll need to know the lengths, so wait until you decide on your new lift so you can get the right measurements.
not really set on beefing up the d30......thats what im here for ......just looking for the best road to take .....i need to do this in steps since im not rich .....what do you guys think i should do first
