Need skid plates for 2012 JKU
#21
Originally Posted by CHRIS@EVOMFG
it will work on a stock JK, Any Fulltraction kit, except for the long arm kit. Any Teraflex kit will work with these. I recommend running Teraflex with our skid systems
here's the weights
Oil pan 10lbs
Auto Transmission 20lbs
Transmission crossmember skid 30lbs.
We built the skids as minimal as we could, to keep the weight down and make the highclearance as possible.
#22
Sponsoring Manufacturer
#23
I'm not sure on the exhaust crossmember skid. I'll try to find the answer and post up
#24
#25
Sorry, it will not work with any long arm. The rest of the skid system will
#28
the crossmember/exhaust cross over skid.
#29
The EVO Protek Oil and Transmission skids work with ALL lift kits. The Protek Exhaust skid (3rd part of the full Protek Kit) will not work with long arm kits. So if you have a long arm kit, order the Oil Pan and Tranny skids (manual or auto) separately.
#30
The AFE Y-Pipe has an interference with the 2012 EVO Auto Transmission skid (manual is fine). I would suggest a driveshaft instead of relocating the exhaust. That way you keep all your emissions compliant and you get the added benefit of a stronger more durable driveshaft, being the stock driveshaft is already known to fail as it is.
Thinking I will go with the oil pan and trans skids then
