Need to reprogram true tire diameter 37" mtr k's
Old 01-09-2016 | 01:46 PM
  #31
nthinuf's Avatar
Just to give everyone something else to ponder ... or argue about.
Using the above trial and error method with the procal (and then measuring to verify height) I found that my tires were 33.5" tall.
A few months later I bought a Flashpaq. Went back to stock on the procal, plugged that height in with the flashpaq, and my speedo no longer matched the gps.
Old 01-09-2016 | 01:56 PM
  #32
jedg's Avatar
Vet Army
Originally Posted by jtphoto JK
So which measurement did you put in your programmer 33.125 or 33.25. I'll bet on 33.00 " being closer with the GPS.
I've been using 33 1/4 for over a year. I'm within 1mph at 80mph.
Old 03-08-2016 | 01:47 PM
  #33
Matthewd5's Avatar
Originally Posted by Mcflurry301
I just had 37" MTR/K installed and I set mine at 36.25 and the speedo seems to be on
I tried 36.25 and even just 36 but the gps and speedo still says I'm going like 23-24 when I'm only seeing 20 on the speedometer
Matthew
Old 03-09-2016 | 09:52 AM
  #34
SoK66's Avatar
At street pressure lay a straightedge across the highest point of the front tire. Measure from the ground to the underside of the straightedge. That's your true diameter. If the speedo is still off my hunch would be you have the wrong gear ratio programmed.
Old 03-09-2016 | 01:11 PM
  #35
Matthewd5's Avatar
I'll try it again but I did set it for 5.13 and connect it up
Matthew
Old 03-09-2016 | 01:23 PM
  #36
Monte417's Avatar
Originally Posted by Matthewd5
I'll try it again but I did set it for 5.13 and connect it up Matthew
Set your tire diameter to 35.25. Done
Quick Reply: Need to reprogram true tire diameter 37" mtr k's
