Need to reprogram true tire diameter 37" mtr k's
I ran a tape measure on mine, 37" MTR's at 27psi on a 2 dr measured something like 36.1-36.2 somewhere in there.
I don't get it either. 15.5 x 2 is 31 + 17" wheel equals 48"?
This is what's worked for me, as recommended by AEV when setting tire size with their Procal module. Lay a straightedge across the top of the tread of the driver front tire. At your street inflation pressures measure from the ground to the bottom edge of the strightedge. That reading becomes the tire size to enter into your calibrator of choice. When I ran MTR/Ks it seems to me the setting was something like 36 1/4" with full tread and 32 psi.
The only way to get actual tire height is to calculate it from the rolling distance of the tire.
Mark a line on the tire at the bottom in the center of the contact patch. Then roll the tire until the line returns to the center of the contact patch. Measure the distance travelled (circumstance then solve for diameter.
Northridge 4x4
This is 100% false. The only way to get actual tire height is to calculate it from the rolling distance of the tire. Mark a line on the tire at the bottom in the center of the contact patch. Then roll the tire until the line returns to the center of the contact patch. Measure the distance travelled (circumstance then solve for diameter. Northridge 4x4
There's more than one way to calculate "true" diameter.
Hrm... sounds like a science project. I might just do this on Saturday if I find time.
Measurement 1 (jtphoto JK) - Measure ground to center hub and double
Measurement 2 (SoK66) - straight edge across the top of the tire and measure to the ground
Measurement 3 (Wrangler X) - Mark center of contact patch on tire and ground. Roll forward until the mark on the tire is centered on the ground again. Measure that distance (gives circumference and calculate diameter).
I'll post the results for my BFG KM2s that are 35s on 17in rims.
