Need to reprogram true tire diameter 37" mtr k's
Hello
My Jeep was in for regular service and only God knows why, but they reprogrammed my tire size to be exactly 37"
It took me a while originally to find a size setting that truly matched my Goodyear Mtr k's
37x12.5x17
If someone is running these on a two door I'd love to hear what size you came up with, I know every rig is different, but this could give me a ballpark number and save me a bunch of time
I had written down all of the programming changes, but we moved since then and I can't find that info
Thanks for any help
Matthew
37x12.5x17
Thanks for any help
Matthew
Hello
37x12.5x17
Thanks for any help
Matthew
37x12.5x17
Thanks for any help
Matthew
The best/easiest way is to measure from the ground to the center of the hub. For a 35 it will be around 15.5 and 16.5 inches depending how much air you are running. Once you have this number, multiply by two and add the wheel size. You will be within a mile per hour or two. This technique has never failed me. Some will say it's not the way to do it, I say it is. I've done it three times now and each time the speedo is almost dead on with a gps.
I replaced both axle assembles, which is both the axle housing plus the axles themselves (dynatrac pro rock D44 and d60) as well as the gearing (5.13) and added ARB lockers as well as new custom drive shafts
I also upgraded the brakes to the dynatrac package
Matthew
