Need new diff cover, will it rub?
So I have a stock JKUR and during some off roading I managed to peel back the rear diff cover and dumped some diff fluid. I used a BFH to smack it back in and torqued the bottom bolts down to take the leak down to about a drip per hour or two, and I ordered a new diff cover.
The diff cover I ordered is the Poison Spyder Bombshell for a D44. However, I did some reading and realized that this will rub the track bar, both front and rear, on a stock. Does anyone have any recommendations on how to fix this? New track bars, relocation mounts, what size lift would I need to make it a nonissue, etc.
Thanks!
Thanks!
I don't believe a lift will help at all. I'm pretty sure your only option is adjustable track bars. I have that same diff cover on the back of my JKU (I have the front, too, but since it's a D30 it doesn't really apply) and I haven't rubbed it yet, but I also haven't done anything off road since I put it on. If you just keep it on the street until you get adjustable track bars you'll be fine. That'll stop the leaking at least. And you'll need to paint those covers since they're bare steel.
Interesting, when I called Poison Spyder they indicated they would both rub stock, front and back, but maybe they only meant full articulation. If all I need is an adj. track bar then great, I'll get one for front and rear and problem solved. Thanks for the replies!
