Need to lower 4" lift
Hey guys!
I'm about to purchase a 2012 JK with a 4" Pro Comp Stage 1 lift. The only hangup is the wife thinks it's too tall. I could lower it an inch or so to make her happy. I feel that all I need to do is replace the coil springs with 2.5" springs to accomplish my goal. Am I correct?
One more thing. This Jeep will be used on mild trails through the woods. No rock crawling...well, no extreme rock crawling.
4" is a lot of lift for what you plan on doing with it. the stage 1 lift in it now might now be the best, most complete lift you can get so lowering your overall height will probably make the Jeep drive better. Unless the prior owner installed drop brackets, adjustbale arms or cam bolts, your caster is probably too low which can cause flighty steering. If nothing was done to adjust caster, then lowering it will give you more positive caster and improve driveability.
Depending on what is in there for bumstops, links and shocks, you may need to swap one or all of those out. You will probably be OK but keep that in mind as I have no idea what the travel lenghts are on the Procomp shocks and what the smallest length you can adjust the links.
If I was redoing my Jeep today, I'd go for a low COG setup even though I do mostly rock type stuff.
If it was 100% my decision that's exactly what I'd do. But to get this rig in my garage I need to let the wife know that lowering it an inch is an option. I can give up an inch and still have plenty of room for the 35's that are on it. It seems I can get a set of coils for around $200.
Thanks for the good info! I've been torn between low COG and the looks of a taller lift. If I give up an inch (making it a 3" lift) do you think that will make much of a difference for shocks, swaybar links, and bump stops? With extreme off-road I bet it would, but for my purpose on trails? Idk.
edit: The previous owner did the stage one lift and that's it. No other mods. So if it wasn't included in the kit, then it wasn't done.
Even at the lower height though, you still have some geometry issues to deal with. But since you didn't drive it stock, maybe you won't notice the steering issues. Maybe....
One last thing....if you like the "Tall" look that comes with big lifts, you can always getthe same look with a smaller lift and flat flares. either trim your stock ones or buy aftermarket. 2.5" lift with 35's and flats looks like a 3.5" lift and 35's with regular flares in my opinion.
Well you know what happens
