Need hood mount for high lift
Old 05-09-2011, 03:05 PM
goncalo's Avatar
Originally Posted by medic_23387
What plastic they are all metal and I have rubber grometts on top between the jack and metal. The reason it looks twisted is because I have to take it off and grind a little off the side of the brackets because I cut mine 1 1/4 inches wide so it doesn't seat in the grove on the hood hinge. That's why I advised 1 inch wide. I have had it up there for 6 months or so and been rock crawling prob 19 times and it has not moved a cm.
Yes, you are correct. You did not say anything about plastic. I misunderstood and did not real properly. I thought you had said plastic tubing for some reason.
Yes very good idea then lol
Old 05-09-2011, 03:51 PM
pcmasten's Avatar
I think ACE Manufacturing makes some that are fairly inexpensive.
Old 05-09-2011, 04:05 PM
JacKed 8's Avatar
Look at my sig for another, cheaper option. $35, pics in profile and they work great.
Sam
Old 05-09-2011, 04:13 PM
JeepSWAG
Sponsoring Manufacturer
Woods's Avatar
Not a hood mount, but a great option for the 4-door: http://www.jeepswag.com/jackmount/index.html
Old 05-10-2011, 07:25 AM
NJ-RUBICON's Avatar
Not a fan on how it will look. I also u hard top so it won't fit
Old 05-10-2011, 07:46 AM
JeepSWAG
Woods's Avatar
Works with any top. Looks, I can't help ya with.
Old 05-10-2011, 08:11 AM
NJ-RUBICON's Avatar
[QUOTE="Woods"]Works with any top. Looks, I can't help ya with.
If it fits I'll look into it
Old 05-10-2011, 08:26 AM
JeepSWAG
Woods's Avatar
I have a couple of rectangle tubes bolted to my hi-lift. I've mounted quick fists on the tubes and I can carry my full size shovel (not shown) and axe. It takes a little longer to get to my hi-lift, but I don't use it very often.
Here's a crappy cell phone pic with the hard top on.
Old 05-11-2011, 06:30 PM
tj_2010jk's Avatar
Get a small piece of 3in by 3in square tubing and cut off two one inch pieces. Drill two holes in the bottom for hood hinge bolts and one in the top to put a bolt through. Place washes on and set jack on bolts then tighten down a wing nut. Thats what I did cost $5.
Hey medic,
What metal did you use? Aluminum, steel? Thx
Old 05-11-2011, 07:34 PM
medic_23387's Avatar
I used steel
Quick Reply: Need hood mount for high lift
