need HELP tonight....please.....
Old 02-22-2009 | 04:17 PM
ucfavenger's Avatar
Default problem solved. thanks again everyone.
I am in the middle of installing a 4" lift and completed the rear including the replacement of the brake lines. I am going to finish the front end tomorrow. Problem is....i need to start my jeep and roll it about four inches forward. But i havent bled my brakes yet.
Can i start my jeep after replacing brake lines if i havent bled the brakes yet????
This is obviously my first time working with brake line mods. I just dont want to f up my master cylinder or something worse.
Thanks in advance!!!!!
Old 02-22-2009 | 04:19 PM
Robar's Avatar
Use your emergency brake to stop and only push your foot brake in enough to get into gear.
Old 02-22-2009 | 04:20 PM
-MAW-'s Avatar
Yes don't touch the brake
Stop using the e brake
So you don't push the air further into you lines
Old 02-22-2009 | 04:21 PM
ucfavenger's Avatar
So it is ok to start the jeep to get the transmission in gear?
Old 02-22-2009 | 04:29 PM
ucfavenger's Avatar
Problem Solved....thanks everyone!
