Need help on TF 2.5
Need help on TF 2.5
Installing this lift and not sure what the instructions are talking about installing rear coil spring guide and spacer. I see it on the install of 3 inch but not 2.5 kit. I'm not going to run the factory isolators yet and there is nothing else in my kit besides a pair of brackets flat washers and bolts. I installed the lower retainers but not sure what's with this other bracket. Or is it the brake line relocation bracket?!?
Originally Posted by duci05
They arnt included with the kit anymore, i just went through this too. Re use the factory rubber piece from top of the spring
I called terflex and this is what they told me.
Ok so the bracket is the brake relocate I fig that out but I have like 4 washers that came in the kit. They are the same size as the washers to bolt on the trackbar. Pretty large in diameter.
