Need help with a strange noise in front end!
Old 01-15-2013, 10:29 AM
cmueller's Avatar
Disconect the sway bar mounts at chassis, move sway bar rubber bushing aside and lube with white lightning spray grease. Reconnect and most likely the noise will be gone.
Old 01-15-2013, 04:10 PM
brizon85's Avatar
I will check both the u joints and grease the sway bar! I'll let you guys know how it goes, much appreciated.
Old 01-15-2013, 04:21 PM
Slewis2604's Avatar
I installed a pro comp coil spacer lift and have clunk on the passenger side rear. I know have a squeak/creak in what sounds like the same fender well. Can't find either one, it's driving me crazy
Old 01-17-2013, 12:56 PM
brizon85's Avatar
yeah i checked my drag link and it seems that it is more loose than normal. I can grab the bar and jiggle it, and it seems to make the same type of noise as i mentioned before.
Old 01-17-2013, 03:24 PM
brizon85's Avatar
Ok so i tightened up the drag link and it still makes that same noise. Next bet ill check the U joints and ball joints i guess. Going to take it in tomorrow and have a shop look at it.
Quick Reply: Need help with a strange noise in front end!
